Double oven and induction hob | on ElectriciansForums
Discuss Double oven and induction hob in the UK Electrical Forum area at ElectriciansForums.net
Tipton West Midlands
Hi all hope to get some advice I have a 40amp fuse in fuse box that runs the double oven 5.1 kw max can I run the induction hob off same fuse the hob is 6.6kw and is 6mm cable ok to use as last person left about 4 meters here from last electrician
Reply to Double oven and induction hob in the UK Electrical Forum area at ElectriciansForums.net
I believe the 6mm and 40A MCB debate is a little contentious at times. It depends on the installation method, being pretty close to the tabulated...
In all likelehood, no different. The RCD on the left is looking for electricity that is going missing in action. If the total missing reached...
