Hi
I'm replacing an old double oven that had a fixed connection to a DP SFCU.
The new oven is rated up to 4.8kW/ 20A on the spec.
I was thinking of just purchasing some 4mm T&E and sleeve the CPC at both ends and connect it to the SFCU where the old oven was.
As I don't know what the old oven was rated at, I was thinking that I should make sure that the FCU suitable for the new load.
What should it be fused at to be suitable? Is my cable choice OK? (It was recommended in the manual).
Thanks,
David
Thanks,
David
