hi, i have just been to look at a job for a customer hes having his kitchen rewired and having a double double oven. He doesnt have the spec or model for the oven.There is a 32amp 6mm cooker supply already in place will this be sufficient to supply the double oven they dont use more than 30amps? just need to double check thanks peeps
Diversity can be applied to the double oven demand so even if they were exceptionally large it is still more than likely that the present circuit will still be suitable.
I do a lot of kitchens and have never come across a double oven needing more than 32A supply
Swansea, South Wales
double oven
mattyevz,
Johno,
