double pole control unit | on ElectriciansForums
Discuss double pole control unit in the UK Electrical Forum area at ElectriciansForums.net
sparky114
Wiring a 2.2kw electric oven.. instruction manual states for warranty to be valid needs a double pole control unit.
There is a double socket inside one of the cubbords; is it ok to spur of this double socket to feed the double pole control unit?
How is the DP socket wired, is it a spur from a ring final?? recommendations are that 2KW and above are fed from their own individual circuit.
Reply to double pole control unit in the UK Electrical Forum area at ElectriciansForums.net
I've seen a few posts here which tend to suggest that wiring in a motorhome (or caravan) wouldn't be subject to normal inspection rules, but even...
Why aren't you asking them?
