Double pole isolation?????????? | on ElectriciansForums
Discuss Double pole isolation?????????? in the UK Electrical Forum area at ElectriciansForums.net
M
mickytuff
Got a puzzler here all..........double pole isolation is used in certain circumstances ie immersion switch, shower pullcord etc, but is it a requirement for it to be double pole and where location wise, special location only or other area's, got me thinking......cant find it in the regs book either, please anybody )) reg number would be the icing on the cake. :grin:
switched spurs and unswitched spurs are normally single pole, i read somewhere that there is a reg regarding the requirement for double pole isolation rather than single pole, its realy buggin me......but thankyou for your reply much appreciated
The very title of this thread actually begs the question.....are you an electrician? You can't have single pole isolation.....really....can you? I mean, if N is still connected....it's not isolated!
i do have another puzzler for you, and it is simliar in nature......a single phase board 48 way,(made by ABB) which has been converted by ABB (was a 3 phase board converted to single phase,why i dont know) but the supply to the board is isolated by only breaking the live, and not the neutral-this is connected directly to the main neutral bar, this cant be good practice as the neutral should be isolated like the live via a double pole main isolator, the rating of the isolator is 125Amps, any opinions on this................
Reply to Double pole isolation?????????? in the UK Electrical Forum area at ElectriciansForums.net
