J
Jktelectrical01
Hi there.
Just looking for a bit of advice, I recently carried out an electrical installation within a kitchen, I never installed any new cables just repositioned the existing cabling.
I used two switched spurs to switch a under shelf fridge and freezer fed from an existing ring circuit.
The b and q electrician came out last week and insisted that I installed double pole switches for the appliances, rarther then switched spurs the reason the electrician had come out was that the oven was supplied and fitted by them selves.
A regulation number proving that dp switches are to be used over switched spurs or any advice would be helpful.
