I've been carrying out quite a few domestic extension first fixes recently which involves providing a power supply installed from the properties mains.
I have always just Henley blocked from the properties main consumer unit tails into a 63/80/100A BS-88 fuse Main switch board then from the board to a 25mm SWA that feeds the extensions consumer unit but I haven't considered that the main switch boards I have been installing only use Single pole + Neutral main switches.
I'm just wondering are these types of main switch boards okay for this type of installation or should I be using a double pole switch supply board?
