double pole sockets | on ElectriciansForums
Discuss double pole sockets in the Australia area at ElectriciansForums.net
B
beanzntoast
Its me:),
Hi all went to a job today to do a board change,did all the tests first everything spot on:confused:,so i changed the board then one side of the RCD kept tripping at 5 minute intervals traced it back to 5 double pole socket fronts.Changed them all to new single pole fronts job sorted.My question is has any of your more experienced guys come across this before.my reasoning was the sockets fronts were old so one of them was causing an unbalance between live & nuetral.does this make sense of am i just talking ********.cheers in advance
jason
My first explanation would be tracking to earth, with them being old. Might be worth testing them if you've still got the old sockets !
Reply to double pole sockets in the Australia area at ElectriciansForums.net
As per above from Dave. Swap to a 63A outlet and problem goes away. What gets plugged into it is not part of an inspection.
That's a hell of a big jump to make, an RCD trips therefore a rewire is required! If a wheel on your van gets a puncture do you go out and buy a...
davesparks
