Double Pole Switch for Loft Light | on ElectriciansForums
Discuss Double Pole Switch for Loft Light in the DIY Electrical Advice area at ElectriciansForums.net
Spud1975
Oxforx
Hi looking for some expert advice on the following .
Am in the process of fitting light in my loft. I have spured off the last light on the end of the radial light circuit using 1mm twin & earth. I would usually utalise a single pole 1 gang switch to switch the live. I believe this is standard practice. On this occasion I would like a switch with a neon indicator so I can tell if the loft light has been left on. To do this I intend to use a 20A ,1 gang, double pole switch with neon indicator to break both the live and the neutral. In my untrained mind this will work and will break the circuit thereby turning the light on/off. But I have never utlised this method of switching.
My question is :
-Is my logic sound?
Is this good practice ?
- Is this safe ?
- does it meet current building regs.
Your assistance with this simple query would be greatly appreciated.
Spud
Should be fine. The earths will need connecting to the earth terminal on the front plate, not the back box. Additional lighting in a dwelling will also require additional 30ma rcd protection.
Reply to Double Pole Switch for Loft Light in the DIY Electrical Advice area at ElectriciansForums.net
Often in old wiring, live to the downstairs switch, then in twin (or twin & earth) the two switched lives to the upstairs switch, and a single...
"It works" and "it's safe" are not necessarily the same thing. With DIY work, they are often far from the same thing.
