double rcd | on ElectriciansForums
Discuss double rcd in the UK Electrical Forum area at ElectriciansForums.net
southside elect
got a split board in a house, going to put a sub board in the attic to supply sockets and lights, do i need an rcd on the sub board.? the main cable going to the attic will be 10mm on a 50A mcb with rcd main switch.
Reply to double rcd in the UK Electrical Forum area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
This is the point of having a trainee badge... it allows you to ask simple questions without the critism reserved for have-a-go heroes. Things...
