doubled cable on a radial | on ElectriciansForums
Discuss doubled cable on a radial in the UK Electrical Forum area at ElectriciansForums.net
Ducksy
Hey guys I see this now and again on my rounds....8.5kw method C on 2 x 2.5mm cable......does it state anywhere in the regs that it a radial must be a single cable Or is it acceptable ? the very least i think its lazy not using 6mm but as always I'm well off from the more experienced guys think ;)
[ElectriciansForums.net] doubled cable on a radial
and the cables must take the same route. if protected with a 40A MCB, the cables should not be overloaded, method C, but , not good practice, IMO.
How would you work out the current carrying capacity of this set up? If its a ring then the maximum overcurrent device allowed is 32a, but this is 5mm??!?!?! where is this cable in BS7671.
Also what happens when one of the phase or neutrals comes out?
i wouldnt be thinking this is an acceptable way of doing things but hey this is why this forum is here!
Reply to doubled cable on a radial in the UK Electrical Forum area at ElectriciansForums.net
