doubling up on mcbs | on ElectriciansForums
Discuss doubling up on mcbs in the Talk Electrician area at ElectriciansForums.net
T
twodds
hi fellow sparks
Ive been told whilst working for my present firm that we can double up on breakers if we are fitting a fused spur to the meters we have been installing,the meters only run 0.6 amps
and we usally put them on a 3 amp fuse and on a 6amp mcb.since being told the regs are changing this year so we can double up i cant see that its right to do this and plus its not on paper yet to the rest of us to do.please can any senior spark shed light on this because im not prepaired to do this unless its ok to do so
cheers Twodds
Seen it done a few times, if overloaded the breaker would operate because remember it would be the sum of the total current from both the spur and the ring flowing through the breaker. Personally I would only leave it as one socket/ lighting point from that spur and label appropriately. It just looks messy in the CU.
Reply to doubling up on mcbs in the Talk Electrician area at ElectriciansForums.net
He said something about a fused something as the lights hardly take anything .. I told him was mostly cordless tools so just chargers ..told him...
Nothing wrong with it. Which manufacturers have you got this information from? What do you mean by trip speed? Fuses and MCBs can operate in the...
davesparks
  • 24/7~ASK#QuEstion>Why are flights so cheap in Turkey?+1-{804}-853-9001
    Why are flights so cheap in Turkey? Flights to Turkey can be cheap for several reasons...
  • [Speak๐Ÿ—ฃ๏ธ AA]โ„ขHow do I speak to American customer service?24&7!!Fast!!Service
    ๐“ฃ๐“ธ ๐“ฝ๐“ช๐“ต๐“ด ๐“ฝ๐“ธ ๐“ช ๐“๐“ถ๐“ฎ๐“ป๐“ฒ๐“ฌ๐“ช๐“ท ๐“๐“ฒ๐“ป๐“ต๐“ฒ๐“ท๐“ฎ๐“ผ ๐“ต๐“ฒ๐“ฟ๐“ฎ ๐—ฟ๐—ฒ๐—ฝ๐—ฟ๐—ฒ๐˜€๐—ฒ๐—ป๐˜๐—ฎ๐˜๐—ถ๐˜ƒ๐—ฒ ๐“ฒ๐“ท ๐“ช ๐“บ๐“พ๐“ฒ๐“ฌ๐“ด ๐“ฝ๐“ฒ๐“ถ๐“ฎ, ๐”‚๐“ธ๐“พ ๐“ฌ๐“ช๐“ท ๐“ฒ๐“ท๐“ฒ๐“ฝ๐“ฒ๐“ช๐“ฝ๐“ฎ ๐“ช ๐“ป๐“ฎ๐“บ๐“พ๐“ฎ๐“ผ๐“ฝ...
  • What is the refundable option on ๐”ผxpedia? Cancellation Policy ยฎ
    What is the cancellation policy for ๐”ผxpedia? ๐”ผ๐•ฉ๐•ก๐•–๐••๐•š๐•’ ๐• ๐•—๐•—๐•–๐•ฃ๐•ค ๐•’ ๐•˜๐•–๐•Ÿ๐•–๐•ฃ๐•’๐• ๐Ÿค๐Ÿฆ-๐•™๐• ๐•ฆ๐•ฃ ๐•”๐•’๐•Ÿ๐•”๐•–๐•๐•๐•’๐•ฅ๐•š๐• ๐•Ÿ...
