down grading of fuses | on ElectriciansForums
Discuss down grading of fuses in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
7029 dave
Mentor
V.Nearly Esteemed
Kent
If a domestic installation has 16mm tails from the consumer unit,lets say old 6way with 60amp double pole switch, and cut out 25mm tails100amp,customer does not want to upgrade fuse board and tails.do you think the dno would downgrade cut out?
Why do you want to change them?
Have you actually done any loading calcs or are you just making blind assumptions based on the (incorrect) pretty pics in the OSG?
Reply to down grading of fuses in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
Yeh that’s my thinking. I have to supply the box so can order a bigger 3 phase option to give myself a bit more room
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
