Down light covers | Page 2 | on ElectriciansForums
Discuss Down light covers in the UK Electrical Forum area at ElectriciansForums.net
goals
hull
Installing some fire rated downlighters in upstairs bathroom (out of zone) and was wondering if they could be boxed in with plywood to keep the insulation in the roof space of themof them...
Even LED need an air gap to cool but they don't get as warm as halogen. You should check the manufactures instructions as you could void the warranty on them.
We came close to a fire in our house, I was lucky to hear the fizzing around midnight.
50W gu10 (mains) halogen MR16 spots inserted into the plasterboard ceiling, with barely 120mm cavity above to the real roof (with fibre glass)
On inspection all the wires (and sheaths) were "crispy" and blackened
Is it the case that leds will be OK (which is what we prefer) or do I need to convert to a surface fitting?
i have stated that they will be fire rated and the main purpose of the question was more a way of keeping the insulation away from the down lights or is the insulation more fire retardant than timber and as someone said earlier just cut the insulation back to the manufacturers recommendations
Do you know what ''Fire Rated'' actually means when applied to downlighters?? Because going by your posts i don't think you do!!
There is always the Bill and Ben solution
[ElectriciansForums.net] Down light covers
Some, and I stress some LED fittings, can be covered completely.
Reply to Down light covers in the UK Electrical Forum area at ElectriciansForums.net
We have some very old delmatic lighting control modules that have pcb and relays for switching they have mostly burnt out. I need to change them...
Better off with the click prw213 as it has twin screw termination.
