Downlight advice needed | on ElectriciansForums
Discuss Downlight advice needed in the Australia area at ElectriciansForums.net
J
james7777777
I have spent all day incorrectly fitting 15 downlights in my kitchen and I now really hate these bloody lights. they are inefficient, cheap, dangerous and dont even light very well and are a pain in the arse to install. Anyway as a result of me incorrectly fitting them many are now very close to joists. Im not moving them but am considering getting fire rated fittings and LED / low energy bulbs. However I havent used these before and would like some advice as to whether they will actually improve safety. I know fire rated fittings arent meant for this purpose but are they cooler to touch? Also do LED's or low energy bulbs run cooler?
Marc
James you have described downlighters in a nutshell.
LEDs vary a lot in their heat output, though all are cooler than halogens. It does depend on the lighting effect you want to achieve.
If you want dimmable then they are coming on the market fairly well but are not really mainstream yet.
If you do not want dimmable then you have a fairly wide range, Halers Evoleds are pretty good but do get hot, do not buy the cluster LEDs unles you want to accent light a particular feature close to the light.
The higher the wattage the hotter they get and they must be kept cool to extend life.
Even where they say they are equivalent to 35W or 50W expect them to be dimmer, but 15 in one room should be OK.
SMD leds give a wide (120 degre light) and are better for lighting a room but do have lower overall light intensity but hardly get hot at all. Single or triple LEDs give a focused beam more like halogens but do get hot, if you can use the 3/4W ones then they are not too bad, around the 9W level they are really like halogens.
Overall though you woudl save loads of electricity using LEDS.
get a decent fitting and pop an LED lamp in it!! if you have living area above the room you installed the lights in to you should have fitted fire rated fittings any way!!
stop been cheap and cheerful especially in your own home!
Marc, If the Kitchen is downstairs and there are rooms above, you should've used fire rated lights in the first place. The best option and the most costly, is to take Mogga's suggestion and use Halers. Or, go and buy some Fire Rated lights and LED lamps. I would be going LED over energy efficient ones as the latter takes a while to warm up - so when you pop in the kitchen to raid the biscuits, you wont be able to see anything for the first few minutes! There was a post a couple of days ago about how close you can put the lights to the joists - might be worth having a look at that one too!
PS -Dont forget its notifiable works too
Reply to Downlight advice needed in the Australia area at ElectriciansForums.net
  • Poll
Hi Folks, I'm looking for downlights that satisfy the following criteria: (1) white bezel; (2) fire-rated; (3) IP65 or above; (4) anti-glare...
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
