Would appreciate any help. I have a bathroom downlight bulb where the pins are too thin for the holes in the plastic cube attached to the wire of the transformer. The other type of pins would be too thick. Is this "cube" missing a part? When the bulb blew I first noticed the pins of the bulb were just resting against the connection points using nothing but gravity! When pushing the bulb into the ceiling, it moves the "cube" too much to maintain the connection. This is obviously wrong, but I don't know what I'm missing.
Many 12V downlighters have a socket that is free to move around on wires that connect back into the light fitting. This allows the bulb to be released and drop lower so the socket can lowered with the bulb for removal etc.
The connections in these sockets can get weak and not grip the pins and can overheat and fail. So a new socket may well be required complete with the wires that are connected to it.
Have attempted to upload photos. Seems to fit Pat H description, though not sure the sockets have got bigger over time.
put a pic on your desktop.then in the forum reply click on "upload a file". then upload the pic from desktop.
OK you need a MR16 lamp holder. i have loads spare. can post you a couple if you pm me yourname and address.
Not sure but it looks like you have to tighten the slotted screws to hold the lamp in . Problem is if you don't get a good connection to the bulb it will keep blowing
I bought a thin flat headed screwdriver and tightened the screws on the bulb pins. This is now resolved. Thanks very much.
Telectrix - that was a generous offer. Much appreciated.
London
Downlight bulb not fitting properly
tim1000,
Barry White,
