Downlight problem | on ElectriciansForums
Discuss Downlight problem in the UK Electrical Forum area at ElectriciansForums.net
H
highspark
Was called to a job last week were 3 downlights in a walk in wardrobe kept dimming out (eventually going off, no dimmer involved) then returning back on after 5mins.
Pulled them down to find all 3 were fed from one transformer. Rewired all 3 and installed a transformer for each fitting. All worked fine.
Just had a call to say that two of the lamps are doing the same thing again but one is now fine. I'm presuming the transformers thermal trips maybe operating? Maybe getting to hot?
Sounds very much like it, what is the ventilation like around the transformers?
If you are pushing them up into insulation and if they are the nice small transformers, that are so easy to get into the holes, then they are more susceptible to overheating.
I assume they are the right rating of transformer!
Reply to Downlight problem in the UK Electrical Forum area at ElectriciansForums.net
Thanks all for the suggestions! Customer doesn't store anything else in the cupboard with the tank, not even towels or sheets. Heatrae stat is...
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
