Sparky_Ben
Just wondering what you guys normally do when wiring these in?
Whether it be a suitable junction box to loop in and out then heat proof flex to the fitting or do you's just loop in and out of the fitting with out using a box?
any thoughts or points of view welcome thanks.
Hi sparky Ben
We started the LINE project through the issues you raise. If a transformer or led driver you will be away from the fitting anyway. I have seen guys wire up to a gu10 but most fittings have low spec connectors and no cable restraint. My (un)biased opinion- use a decent jb and connectors. Will make the job easier and to a higher spec.
L
downlighter wiring
Thread Tags
Sparky_Ben,
Hawk81,
