Downlighters - 12V or 230V? | on ElectriciansForums
Discuss Downlighters - 12V or 230V? in the Australia area at ElectriciansForums.net
240v so that once LED lamps become affordable and bright enough they can be fitted easily.
Also don't like all the hassle with transformers except in the winter and if I'm not busy all the call outs I get to fix them!
I tend to fit 230v downlights now with either compact flourescent bulbs or led bulbs, I try to steer people onto the flourescent bulbs or led bulbs as the standard gu10 bulbs produce lots of heat & costly to run, I have replaced a few sets of gu10 fittings with 11w compact flourescent fittings for people because they did not like the heat produced by them and they were having to replace bulbs very frequently, and they all seem to like the cfl's better.
hang on, 12 v or 240 v
12 volt all day long untill thay started LED
I know nothing but i know one thing fitted out many local PUBs in the area years later changing lamps and years later transformers these are on 24 7.
G U 10 well one week may be Two if lucky and the cost of lamps.
plus dimming, dimming dont ask about dimming led
good luck forget cost 12 volt nice and crisp
Have to agree on 12v, gives a much better crisper light
I installed 4 12v into my bathroom 3 years ago and im still on original lamps and transformers
around the same time i installed 4 230v gu10's in my passageway, changed numerous amounts of lamps, they also give a yellowish glow, only reason i fitted them was because the fittings were surplus stock from a job
GU10's are expensive to run. for a decent sized room you need 6 downlights, thats 6 X 50W =300W. that is 2 and a half times the power when compared to say 2 X 60W bulbs. when i explain it like that to people they always go for the low voltage lights. and GU10's kick out alot of heat too, they just seem in-efficient to me
If you're going halogen 12V are always preferred in my opinion. Buy good transformers like the Aurora AU-E60s and you won't go far wrong. Much longer lamp life due to soft start on the transformer and far better light output. However, if I'm not specifying halogen then it's Halers EvoLEDs all day long!
Great 2 see the 12v brigade out in force lol its normally the other way round! i have to agree with previous post buy good quality lamps and transformers and theres no problem, i wired a house 2 years ago full of lv downlights was back recently and the customer actually commented that he's only had to change 3 - 4 bulbs!
Reply to Downlighters - 12V or 230V? in the Australia area at ElectriciansForums.net
There is a glass disc under the lamp that is also fire rated.
loz2754
L
Thank you for your reply. I manage to find the issue I think, the natural and live wasn't inserted properly in one the wago Further down causing...
