G
Gerry24
Been asked to change 8 downlighters in a kitchen to 8 mini-pendants. I've never installed downlighters before so would be grateful for a bit of advice. They are all operated off the same switch and I can only have access from the ceiling as the customer does not want me to lift floorboards above. But, they are having the ceiling re-plastered so no problem with cutting a few holes in the ceiling to access junction boxes etc if necessary. So, just a straightforward job to change downlighter fittings to pendant fittings then or is there anything quirky I should lookout for?
