Downlighters for garage gutter, whats it called? Soffit board. | on ElectriciansForums
Discuss Downlighters for garage gutter, whats it called? Soffit board. in the UK Electrical Forum area at ElectriciansForums.net
Market Harborough
Hi,
The garage install I finished off today, pleased with it, looked good! Where the customer originally had taken a 4 way bar apart, stuck some twin and earth in it, and poked it through the wall and connected it off the back of the lounge socket, I went to disconnect it today as last part of the jigsaw and he had only gone and connected the live to neutral and vise versa!!
Anyway, back to the question, he has a very narrow soffit board if that's what you call it because of the way its built, and there's only 50mm space. He would like a few lights in in, i have had a little look about as has he for something that will fit but not much luck.
So does anyone have any thoughts on what might fit in a 50mm gap to appear to be like down lighters to go across his garage door?
Access above is just possible, but its limited. Just needs some narrow led lights maybe.
like this?
[ElectriciansForums.net] Downlighters for garage gutter, whats it called? Soffit board.
Hi,
To much info mate, there must be other websites you can frequent on a Saturday night, if your into that kind of stuff :crazy:
Reply to Downlighters for garage gutter, whats it called? Soffit board. in the UK Electrical Forum area at ElectriciansForums.net
When you did the further testing and got the 0.06 reading were the CPC's back in the consumer unit? Really when testing you should leave the...
