Downlights/Spots replaced with pendant - is cable OK? | on ElectriciansForums
Discuss Downlights/Spots replaced with pendant - is cable OK? in the UK Electrical Forum area at ElectriciansForums.net
Y
ydrol
Hi my dining room is two rooms knocked into one. About 20ft by 10ft.
I recently had an electrician replace 6 rather ugly down-lights (R80 spots) with two pendants at each end, as I plan to rent the house at some point in the future, and this would be more practical and economical arrangement.
Anyway, The electricians had to run new cables (spurs?) to the pendant locations, I was happy with the work but my mate said that he thinks the cable is too flush to the ceiling.
Note that I am getting a plasterer to skim the ceiling flat in the near future to give it a modern look. The electrician was aware of this.
What do you think , should the cables have been recessed more?
[ElectriciansForums.net] Downlights/Spots replaced with pendant - is cable OK?[ElectriciansForums.net] Downlights/Spots replaced with pendant - is cable OK?[ElectriciansForums.net] Downlights/Spots replaced with pendant - is cable OK?[ElectriciansForums.net] Downlights/Spots replaced with pendant - is cable OK?
the better option would have been to drill through the joists > 50mm above ceiling. however, that would entail either cutting several large holes in the ceiling or lifting a few floorboards in the room above.
That is a bodge, it would be far more normal to run cables through holes in the joists and not chip little bits of ceiling out. Normally this is done by lifting floors above, but if you are having the ceiling skimmed anyway then hols can be cut in the ceiling and the work done from below.
That is exactly how I have one it in the past, knowing the ceiling is going to be skimmed anyway hat does it matter if you have a few extra holes to repair? I have cut 6inch holes I the past to allow a angle drill in and made sure the joist are drilled 50m from the ceiling.
A clients husband once walked in as I was finishing pulling cables through holes this size and said; " Blimey, what size down-lights has she asked for?"
I just cut one long strip out of the ceiling along the length of the room, then screw it back up to the joists when finished,
Tricky one as safe zones don't make any mention of ceilings however the guidance is that cables installed above ceilings should be a minimum of 50mm above the ceiling surface to prevent damage. I agree with davesparks....it's a lazy bodge.
Lets hope the end user doesn't hang Christmas decs with drawing pins like someone I know does....might be their last Christmas.
Yes, I'm trying to get the age of the Artex checked, but I suspect it is around 2000.
Good point about the Crimbo decorations! I'll get a statement from electrician as he has not issued certificate yet, but will make sure that is mentioned on any tenancy agreement if it's not changed.
In my opinion that's a terrible job, Fair enough if the ceiling was being studded off and lowered, It might not be against any regs but it just screams laziness,
OP was it possible to get floorboards up above?
With the ceiling being plastered anyway I'd not normally consider the floorboards above, just make holes in the ceiling. Unless of course there's a loft above
Reply to Downlights/Spots replaced with pendant - is cable OK? in the UK Electrical Forum area at ElectriciansForums.net
That's why I directed the OP towards:
