Downlights Tripping Breaker | on ElectriciansForums
Discuss Downlights Tripping Breaker in the Australia area at ElectriciansForums.net
M
mcummins7
I've got a circuit tripping out the breaker (not the RCD it's on) when the lights in the bathroom are turned off only. The lights in the bathroom are six downlights on one switch.
Is this a problem with downlights? Is it common?
Oh, BTW it's not the switch as I've replaced it.
Sorted problem. Looks like the circuit was part of a lighting ring circuit, or a line/neg taken from another circuit. I guessed this as the lights wouldn't trip if the other breaker was off. Once I ran both lighting circuits from the same breaker - no problem. There were six lighting circuits in all.
Reply to Downlights Tripping Breaker in the Australia area at ElectriciansForums.net
Neutral and live
clearly a wiring or connection issue, lets see a picture of your connections
