Downlights | on ElectriciansForums
Discuss Downlights in the Australia area at ElectriciansForums.net
G
gavjamin1989
how do you wire your down lights because I've been taught to put the twin and earth in connectors then flex out to the light and put a choc box over the connection as regulations state that twin and earth can only be connected into fixed lights is this true or have a been fed a load or old rubbish
I always use 17th edition J/Bs,spot on for downlighters
Ashley J501 16 Amp Downlighter Junction Box[ElectriciansForums.net] Downlights Ashley J501
The IEE Wiring Regulations state that terminals shall not be subject to undue stress,
i.e. taking weight of cables or fittings.
Currently a high proportion of Junction Boxes are installed behind Downlighters or
decorative light fittings, where moving the Junction Box in to position after wiring
could cause stress on the terminations.
With the NEW Ashley J501 Junction Box, these obstacles can be overcome.
Ashley can provide a quick and easy means of connecting fixed wiring to flexible cables of downlighter fittings based on 3 main benefits:
1. Easy to use
2. Wide application suitability
3. Compliance with latest regulations
1. Easy to use
these look brill its a shame ive never seen one in my life lol i use the wago line but the exspensive and bulky
Reply to Downlights in the Australia area at ElectriciansForums.net
Often in old wiring, live to the downstairs switch, then in twin (or twin & earth) the two switched lives to the upstairs switch, and a single...
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
