Downstairs toilet... regulations | on ElectriciansForums
Discuss Downstairs toilet... regulations in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
West Byfleet
Hi,
Currently rewiring my new house and have accepted that the building inspector wants and extractor fan in the downstairs loo. However I'm struggling to work out what is acceptable in regards to "zones"
There is no shower or bath, but there is a small sink and the toilet.
The extractor requires a 3A fuse.
I can't seem to see a statement in the regs or onsite guide to what the zoning requirement actually is for this small room.
As a 3pole pull cord fused fan isolator doesn't seem to exist can I fit an Ip20 rated fused fan isolator switch to the wall above 2.25m ?
There are no specific regs for a wc, it is not a special location.
Fan is under building regs not electrical regs.
As above. Not a special location, as it’s not “a room containing a bath or shower”
It’s just common sense not to put a double socket next to the basin.
Although, it’s somewhere to charge your phone when you’re taking a dump
could it be Fentilation??
anyway, as regards fan... why not fedd separate from lights, switch on outside of room, alongside light switch. get rid of the dangly strings.... so 1970's. and if there's a window in the room, no need for a 3 pole isolator. (there's enough Poles over here as it is. :)).
anyway, as regards fan... why not feed separate from lights, switch on outside of room, alongside light switch. get rid of the dangly strings.... so 1970's. and if there's a window in the room, no need for a 3 pole isolator. (there's enough Poles over here as it is. :)).
Strangely I cant stand the ugly fan switch being on the outside of the room, will ruin my hallway feng shui! I've had to relent for the 2 bathrooms upstairs but the downstairs bog is having a dangle one inside the room. my building inspector seems to think there is need for extract ventilation even though its only place can be directly above the opening window...
Fan will have its own feed from the junction box in the ceiling with a switched live for the timer from the lightswitch.
or you could fit an occupancy sensor. no outside switch and no dangly string.
Reply to Downstairs toilet... regulations in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
