F
fog
Hi please can someone help on relay wiring. I have a dpdt relay of 30 amps(all 230v) i am using a central heating control to power the coil to turn relay on, as i understand i put the switched live and neutral to pins A1 and A2 from central heating control, to energise the coil to switch the power. Which is switched via coil operation from common terminals (live and neutral) to NC, (normally closed) to pass the power through the coil to turn load on? and i ignore the NO (normally open) terminals, is this correct?
A Double Pole Double Throw Relay comes with 8 terminal points.
The terminals are COIL, COIL, COM, COM, NO, NO, NC, NC.
never wired relay before can do with some help.
many thanks
many thanks
