DPM4 condition report help | on ElectriciansForums
Discuss DPM4 condition report help in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
demkap
hi all could someone explain the breakdown of the schedule of inspections as its a bit confusing regarding all the technical language.
Inspections 5.19 and 5.20
adequacy of working space/accessibility to equipment
single pole devices for switching or protection in line conductors only
if someone could explain this that would be great
many thanks
Accessibilty to equipment, and working space, can items/equipment be accessed easily for testing, servicing, monitoring and reset etc...
Single pole devices switching line conductors only - basically as it says .. you haven't got any single pole devices breaking the N when they operate instead of the L.
PS - this is just my easily translated expression of it and may be worded differently in the books.
Reply to DPM4 condition report help in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I don't think I'd use it mate even the one line heading then one long paragraph screams ai. And untrustworthy. I don't think much has been edited...
    • Optimistic
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
