Draining radiator? plumbing advice | on ElectriciansForums
Guest viewing is limited
  • Thread starter ben100
  • Start date
  • Replies 0
  • Views 74
Discuss Draining radiator? plumbing advice in the Plumbers Forums area at ElectriciansForums.net
Draining radiator? I’ve got this radiator that I need to drain down & remove to clean out due to sludge. Can I drain it with that drain valve on the left because as you can see that it connects to the radiator but that pipe also runs along past the radiator on the right?
[ElectriciansForums.net] Draining radiator? plumbing advice
Draining radiator? to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to Draining radiator? plumbing advice in the Plumbers Forums area at ElectriciansForums.net
G
Radiator flex pipes Could I pull these flex pipes up by cable tying them onto the back of the radiator (it’s a double rad) Just wondering if the...
Glasgowman
G
Isolating valve Is it good practice what I'm planning to do. I want to drain the central heating and then put 2 isolating valves on the flow and...
dwalsh1
Recommended Sponsor News
Hi everyone,
Email
Time zone
Last seen
Plumbers Forums
Thread Tags
Tags
None
