Drayton LP822 Once button results in permanent hot water | on ElectriciansForums
Discuss Drayton LP822 Once button results in permanent hot water in the Central Heating Systems area at ElectriciansForums.net
EddieB
Guys
Encountered a problem using the above function, when the once button is selected for a boost on the CH the Immersion heater will not then switch off. I have to switch the programmer of for it to reset... any ideas??
The boiler is an Ideal ICOS and the Tank controls are Range
Guys
Once will stay on until the last time its set to go off.
I suspect a y-plan? if it is more than likely a problem with HW off/satisfied side of the wiring or component failure of the programmer or cylinder thermostat. Work through the sequence of switching with your multi meter.
Reply to Drayton LP822 Once button results in permanent hot water in the Central Heating Systems area at ElectriciansForums.net
You need a wi fi switch that is compatible with your switchbot thermostats. Remove the SCR, use the neutral and live to power the wifi switch, and...
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
