Drayton remote roomstat. | on ElectriciansForums
Discuss Drayton remote roomstat. in the Central Heating Systems area at ElectriciansForums.net
I
itselectric
I have a one of these units fitted to my central heating system. Problem is it's stopped working. I have read up on it, and it appears these particular stats have a problem, which can be repaired. I have ordered the bit thats required and at the price of ÂŁ3.30 its a lot cheaper than a new stat.
My question is, has anyone had to repair one and if so how long did the repair last. or for that matter did it work?
Wouldnt know about repairing. sometimes when the battery runs out, you have to pair it up to the controller again.
Or has the relay not clicked on the scr. This can be the capacitor has failed, i believe this is the repair you are talking about.
I've checked batteries and gone through recommended checks which have led me to believe the receiver is faulty.
And yes this is the repair I'm on about.
thanks for reply, as what you have said has convinced me I'm right about problem
Thankyou for info TCES. But I've already sent for the capacitor and will do repair, it looks fairly straightforward.
My original post was to find out if it was a common problem and if it was worthwhile doing repair,
Reply to Drayton remote roomstat. in the Central Heating Systems area at ElectriciansForums.net
glad it was such a simple fix..... And good job the previous owners didnt take it with them
You need a wi fi switch that is compatible with your switchbot thermostats. Remove the SCR, use the neutral and live to power the wifi switch, and...
