dreaded flat plate accessories | on ElectriciansForums
Discuss dreaded flat plate accessories in the Electrical Tools and Products area at ElectriciansForums.net
K
Kiers1970
Anyone tried the cavity boxes specially designed for the 'orrible flat plate accessories?
Just done a first fix and rebated the boxes so they are flush when fitted.
Reply to dreaded flat plate accessories in the Electrical Tools and Products area at ElectriciansForums.net
It won't be notifiable though as its not a new circuit, if you change the the tails from 16mm to 25mm is that notifiable? No, if you add an...
When I first started, I stripped out a house for a rewire and got my hands on a switch with an inlay and transparent cover. Filled it in with...
