Dressing in 10mm cables | on ElectriciansForums
Discuss Dressing in 10mm cables in the UK Electrical Forum area at ElectriciansForums.net
dnjr
South coast
Dear All
Have to terminate 2 x 10mm t&e cables in a back box and isolator switch ( for a shower )
Gone for a double 46mm box and cooker switch but can’t find a tidy way to dress the cables into the box
So. What do people do. Cut them shorter and pre bend etc or leave them longer and curl them around the box
Don’t have popeye hands and am struggling
Advise appreciated
Ta
easy peasy, unless its the smokeless cable
leave a little spare above the box for you to work with, connect the cables as normal, slide the cables back into the wall above the backbox, like a glove.
Hi westward
That was my thinking but don’t have the finger strength any more to dress the properly
What are you calling Short and what length would you suggest leaving
( got 10 of these yo do !!!!)
Cheers
tort
When I say short do not cut them so you cannot pull the front plate forward a sensible distance. I would have a bit of practice by screwing a back box to a board with a couple of bits of 10mm.
Perhaps short side entry, run length of box, gentle u turn, return half way and 90 bend to face plate. Length approx 2 x box and trim to fit. Do a practice one ?
Terminating 10.0mm at domestic grade accessories has never been ideal and this is why you see so many burnt out conductors at pull cord isolators, inadequate space placing undue stress on conductor connections which nine times out of ten have exposed conductors pushed through back boxes and exposed in the ceiling cavity.
Agree. 10 can be a bugger to get in right without then later coming loose when you screw it. I sometimes warm it up a little first by giving it a good rub. Hold it with one hand and have a good cloth or glove on the other hand to rub with. Hasnt dissapointed me yet and the cold weather dont help either. A bit like conduit.
All too often i have come across 10mm with strands either purposely cut off or snapped leaving just 2 or 3 strands in the terminal. Some people are lazy
Reply to Dressing in 10mm cables in the UK Electrical Forum area at ElectriciansForums.net
It is actually specified in BS7671 that the cpcs must be connected to all other sources of earth.
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
