Totally fed up with this one.
Any thoughts on hole drilling to run cable down a stud wall, I cannot get a straight line through.
I am trying to run cable from the loft down to the CU in the hall.
I have drilled down 1.7m and can take the drill bit up 1.7m and the total height is about 3m.
I have run cable rod up 6m! and should be out through the roof, but I cannot see the rod at the top.
Rodding down I hit something just below the last down drilled hole.
What am I doing wrong (apart from not drilling the holes by taking out the plasterboard at noggins)?
Any thoughts on wall construction, etc.
Thank you!
Thank you!
