rfears
Excuse ignorance but here goes anyway.
I want to take a cable (2.5 T&E) through an external wall. Lets assume its a normal cavity wall.
My instinct would be to drill down from inside to outside (or up from outside to inside) to minimise damp ingress -maybe 10 or 15 degrees.
I would then want to fix conduit to the outside to guide my T&E to it's ultimate destination.
Two questions:
1. is my instinct right (i.e. angle through wall) or is there a BR recommending against this?
2. whatever the orientation of the hole is there a commonly available conduit component that I can fix over the hole to take the cable into the rest of the conduit run?, and if so how do I waterproof it to minimise damp ingress into the wall? (OK, technically that's 3 questions)
Rick.
Two questions:
Rick.
