E
electronicman
Hi I need some help,
I want to transform in my circuit a double inverter relay in an electronic control.
The only way I've found, is 4 triacs (one in each path of the relay) which their trigger is controlled by a microcontroller.
The circuit is driven by reaction of an accelerometer which inform the chip which stop 2 of the triacs and in the same time supplies the others.
The problem is that I need 35mA in each trigger of the triacs and the maximum we should take from the output of a PIC is 5mA and the supply is a battery of 5V.
The second problem is the triacs,are they really reliable if i need a fast answer when i cut the trigger current?
