Driveway alarm with security lighting and audible chime | on ElectriciansForums
Discuss Driveway alarm with security lighting and audible chime in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
london
I'm looking for some driveway security,
The plan is for a gated front garden, with sensors to active all the security lights and an audible chime.
Best to stick with wired products as the driveway is being done anyway.
have used these before. 12V sensors wired back to a control box which has manual override and a buzzer. controller then powers your security lights @ 240V
12v infrared sensors across driveway controlling a relay to bring on lights and bell chime is a possibility.
If you can wait until September then Hikvision a releasing a floodlight camera.
I think any external sensor will drive you mad with a chime. Foliage and the neighbours cat with have it chiming constantly.
I bought a kit from Amazon...it worked just fine. battery powered sensor signalled a plug-in chime in the house, and a PIR flood did the rest. It was ÂŁ20, it's still working 5 years on.
[automerge]1597795410[/automerge]
and I have Hikvision camera which alerts me to any significant movement, and is scalable. It works fine too.
getting one with a built-in flood would indeed be a good choice
Reply to Driveway alarm with security lighting and audible chime in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
These keypads are obsolete and replacements are hard to find, I've replaced loads now with failing displays. Sounds like something isn't...
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
