Dry lining box | on ElectriciansForums
Discuss Dry lining box in the UK Electrical Forum area at ElectriciansForums.net
Resu
Mentor
Scottish Highlands
Just picked up a wee job that has been first fixed. The finished walls are made up of something like 6 or 8mm ply. We usually use Appleby fast fix boxes but I tested one and they won't tighten up due to the thinness of the ply. I was wondering if there was a dry lining box available that would do the job? (ie. less space between front of box and lug). Trying to avoid metal boxes as nothing has been dwanged!
Appleby used to make little spacers which fit in the holes on the yellow lug face to accommodate thinner wall panels. My local branch of Holland House used to keep them. However you may well be quicker to use the wood glue & off-cut method suggested previously.
Found them by a quick google "Appleby packing pieces". Shudder to think of the cost but will ask my CEF rep next time I see him. Looking like I'll have to make my own! Cheers guys.
Reply to Dry lining box in the UK Electrical Forum area at ElectriciansForums.net
Nothing wrong with it. Which manufacturers have you got this information from? What do you mean by trip speed? Fuses and MCBs can operate in the...
davesparks
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
