Hi guys,
Got a Citroen DS3 with a rather strange fault. The tail light brake lights (Left and right) never work with the brake pedal, however the actual bulbs are fine because they light up when the lights are switched on (but the brake light always stay on). Checked the brake switch and it meters fine and the strange thing is the centre light on the rear glass works with the pedal as expected.
So the bulbs work, the brake switch works, fuses are fine and wiring to the brake bulbs must be fine because they do work only with the lights switched on.
Any ideas please? Any input would be appreciated as I'm baffled! Cheers
