Dti Guide | on ElectriciansForums
Discuss Dti Guide in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
M
moggy1968
got my inspection tuesday
are we now working to the new guide yet, does anyone have a link?
I can only find a provisional document
someone will post the link shortly, but this blog post from one of the authors is relevant if you're referring to the earthing of the array frame etc.
[h=2]Array frame earthing and transformer-less inverters[/h]One reason I am frequently asked about the publication date for the new guide is due to the proposed changes to array frame earthing on systems with transformer-less inverters. This section of the guide has not changed significantly from the published draft and I do not foresee any alterations prior to publication. As the new (draft) guidelines are widely accepted throughout the industry many of the MCS certification bodies (eg Elecsa) permit installers to operate to the new guidelines. My message to any installers who ask about this, is to suggest talking to their certification body and seeing if the CB can provide, in writing, that you can follow the new guidelines.
Solar PV installation guidelines - The solar PV blog » The solar PV blog
ah right, ok, well in that case you aren't working to the draft guide anyway, in which case the 2006 version is still the official guide, and you're still working to it, so there shouldn't be a problem.
Check out GN7 which has been updated for Amd 1, decision tree states that it needs bonding if extraneous or earthed if the frame is an exposed conductive part.
In the introduction to this special location it refers to the DTI Guide (2nd edition) and says that it is currently being re-written as the Installer Guide to Photovoltaic Installation 978-0-901452-48-1 - under the auspices of the MCS scheme.
There is also a decision tree on RCDs as well!
Has the new v3 DTI Guide been issued yet? I haven't seen it but noticed that some of the training providers were offering training last week for it (not that I'd be spending cash on training when I've got plenty of time to read it this time!!) I just wondered if I'd missed it and if I haven't how can you do a training course on a guide that hasn't been published?
Had my assessment last Thursday (passed with no non-cons and assessor thought our installation was 'outstanding', since you asked :cowboy::biggrin5:) Anyhoo, I'd just got back off me hols in the early hours of the day before so I asked him if we were working to v3 yet. The answer was no and he didn't have a clue when it would be issued, although it was supposed to be 1st Oct.... <edit> he did mention something about the DTI guide and MIS3002 being merged into one document </edit>
Training companies seem to be manure powered these days...
I'd be suprised if that happened, as of course systems > 50kWp aren't covered by MCS... also the problem is that the DTI Guide, is just that - a guide, whereas the MCS tends to be legislative and not open to interpretation. I may be wrong as of course it was issued through the MCS website ..... Worcester rambles off into the distance ....
I had a long chat with one of the main authors a few weeks back who said it was all done other than their revision of SAP, which I suspect is still the stumbling block, as IMO their proposal is only marginally better than the previous abomination. They seemed not to know that there can still be massive differences within a region eg between the Yorkshire dales and the Yorkshire east coast there can be up to a ~25% difference in the average number of sunshine hours per year, yet these locations would all be treated the same under the revised version of SAP.
I pointed out how utterly useless this was, to the response that they needed to find a reasonably simple method of estimating performance... so they've gone for simplicity over accuracy.
[ElectriciansForums.net] Dti Guide
I guess back when they started to dream up the change the industry was in a much better shape, with 10000 installs a week. Rogues and gold miners were signing up to MCS in there hundreds. Such a different landscape now, being back to a cottage industry things now take longer. Why rush.... ! Greg Barker the butcher of solar doesn't give a hoot, his moved on to the green deal now.
a point about the green deal you may not know you can get the FITS from the green deal if you make a contribution to the install cost .
so if you pay say 50% of the installation you will get 50% of the FITS.
I thought you'd get all the FIT because green deal is charged at commercial interest rates and therefore not state aid.
why would anyone use green deal for PV if it reduces the FIT income?
SAP 2012 has been available in draft form for about a year. There is a new method of calculating irradiance based on postcode. There is no reason why this could not be refined further to satisfy Gavin's point. Irradiance is not the same as sunshine hours. It is better than SAP2009 but not perfect. The calculation is fun to say the least.
DTi 3 will be called something like the ECA guide. It should have been published by now. I was asking at Solar Power UK about the delay and was unable to get a straight answer. I know there are concerns in other technologies about the plethora of standards, (eg MIS and BS/EN) and what ends up taking precidence. Worcester is right to point out it is a guide, but it is the one we are measured against.
I'm seriously thinking about refusing to even use sap at all, see if they'll actually try to sanction us for using a more accurate method of estimating performance that we can back up with data from dozens of installations, and warranty to be within 5% of our estimates (allowing for variations in irradiance).
Reply to Dti Guide in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I contacted bp pulse and they needed the serial number before even discussing what might be at fault... When im out at it next, ill take cover...
You need to pass the job on to someone who is competent and up to speed with solar installs and regulations .
