I got a job next week to connect up a hot water cylinder which has dual 3kW immersion heaters. Ideally I would run 2 new 2.5mm circuits from 2 16A MCBs on separate RCDs but there are not enough spare ways in the CU. Is there any reason why I shouldn't run a 4mm radial on a 32A MCB and split it at the tank into a timed and a boost immersion.
It's only about 7m of cable under a floor.
Cheers
Cheers
