Dual immersion help please | on ElectriciansForums
Discuss Dual immersion help please in the Central Heating Systems area at ElectriciansForums.net
south west
Hi everyone, need your expertise on hot water tank set up,
theres a large hw tank with dual 2.7kw elements with stats
controller isn't working as micro switch is broken, but house has new ish economy board supplying about 7
night storage heaters but spark-plumber has installed hw tank on normal board 24-7hr supply,
question is should i move the supply over to the economy board and there is a boost function, is this supplied from 24-7 supply or is it on same as economy supply? boost is currently wired to bottom element and normal water heating is wired to the top?
i don't come across these hardly at all, I'm use to single element tanks and don't do much heating controls,
think its time i did.
any advise welcome, thanks guys.
hello i would leave it as it is & install a QE7 24 immersion timer with boost function, this has time clock for the night time function & a boost button for the day time.
Reply to Dual immersion help please in the Central Heating Systems area at ElectriciansForums.net
This is an RSS feed of thread: Two electrical supplies and a single immersion element Content of the thread: Good afternoon, new joiner here with...
By the time you've dealt with isolator valves that won't shut off and drain valves that won't open, half a day will be gone before you've removed...
