Dual rcds tripping | on ElectriciansForums
Discuss Dual rcds tripping in the Talk Electrician area at ElectriciansForums.net
Davem
Evening gents bit of advice required please I have recently finished a partial rewire (upstairs sockets upstairs lights and smokes). All is fine apart from when I turned under unit lights on in kitchen it tripped both rcds. There is 1 2 gang switch in kitchen 1 for main kitchen light and 1 for under unit I have taken link out from main light switch the under unit light switch and this rectified the problem no tripping but when I put link back in both tripped again and ideas guys cheers by the way pretty new to the game so be nice
You need to carry out an IR test on the suspect circuit, more than likely a NE fault.
Big mistake mate with the "new to the game" and "be nice bit"..tripped both RCDs?? christ why does none of this exciting stuff happen to me?
As above sounds like crossed neutrals, time to get the tester out
Back there tomorrow guys working Sundays love it so will do as advised I have tested all new installation and all is fine gotta test old bit tomorrow looking forward to it a will get back to you with results cheers guys
bet it's a shared neutral between 2 lighting circuits or a N in wrong bar in CU.
No borrowed neutral all lighting is segregated to individual circuits Everything works fine other than under unit lights
Reply to Dual rcds tripping in the Talk Electrician area at ElectriciansForums.net
Ok I’ll try this when I’m down
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
