Duff electrics | on ElectriciansForums
Discuss Duff electrics in the Talk Electrician area at ElectriciansForums.net
E
ezzzekiel
ok here goes,
with socket circuit switched on lights go dim, switch off mcb for sockets lights are fine, similar with other circuits ex. cooker circuit is fine with sockets off but drops off when sockets switched on.
seen similar with a damaged service fuse and loose neutral at incomer but both checked fine, (mate on the job at minute and rang for a quick fix) cant think off anything else unless im missing something?
mate just swapped the meter (meter engineer for bg) and fault (has apparently) just appeared - so going from the info im given cant see the sudden connection
he swapped meter out for a reconditioned one still same so replaced with new one still the same? mentioned the board looked newish but supposedly been fitted a few months
his problem being he cant get a polarity check on the sockets which he needs to confirm the job is ok
I'd have said more to do with high resistance connection on the incoming supply.
Most likely voltage dropping under load (Measure it!) - any type of loading that significantly dims the lights on a good installation would certainly trip the relevant MCB.
Do a PSCC at origin - you will likely have a miserably low figure and something somewhere will be getting very hot under load.
Also, particularly if TN-S do the PEFC.
If the PEFC is significantly higher than PSCC you have a high resistance connection on the incoming neutral, most likely on the DNO side.
This would tie up with not being able to get a correct polarity test on the sockets, as the neutral will be lifting up several volts relative to earth with this fault.
Simon.
Simon.
i suspected this seen it before, where a damaged service fuse hadnt blown but created a high resistance and was actually coming from a linked fuse from next door but he swapped customers fuse and says its not linked incoming direct from street
getting no reading with martindale.
Simon.
pme system and he dosent have the gear to carry out those sort of tests
Well there's obviously some power there, so maybe the actual voltage that's getting through under load is below the threshold that the Martindale will light at.
Bet it reads correctly if the loading is removed from the sockets before testing.
Simon.
Erm this is probably rubbish but is there any way it's a split load board that has somehow been wired in series? Had too many beers to think about it proerly, so I'm just throwing it out there.
Reply to Duff electrics in the Talk Electrician area at ElectriciansForums.net
As a trainee, one of the things I've tried to focus on to deepen my interest in the world of electrics, is the space for creativity. I've...
    • Winner
