Dumbo brain freeze | Page 2 | on ElectriciansForums
Discuss Dumbo brain freeze in the UK Electrical Forum area at ElectriciansForums.net
London
Hi all, having a stupid moment. Come across this today on job. See photo. It's RCD supplying 10mm shower. As you can see the supply side is coming in on bottom load side so to me that's complete no no but what I'm not clear on does this RCD offer any sort of overload protection.....is it actually a RCBO? I've not come across this manufacturer before . The In rating is the current setting of device. Which in this case is 63amp. So is this infact the overload rating....63? Just that I always thought this In rating on RCD's was just the level of current it could safely withstand with out damage but is not actually the rating for overload protection
  • [ElectriciansForums.net] Dumbo brain freeze
Is that a new AD range then, I have a few old ADs and they have a neutral fly lead.
I hate progrrss...?
I don't know how new they are, but I installed my first one about two years ago, I think, this lock down has me very confused about when I last did some work.
Reply to Dumbo brain freeze in the UK Electrical Forum area at ElectriciansForums.net
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
