Hi Guys & Gals,
So Im fitting two small 1.7kw storage heaters on Monday. There is already two fitting, fed from an old Wylex cu with rewireable fuses. The cable for the excisting heaters are buried. So my first thought was to fit a new 4 way rcd board so I could add the two new ones. Now I know you can have problems with nuisence tripping of the rcd when the E7 kicks in so, heres what Im going to do!
The customer doesnt want me to chase the walls, he is fine with the cable being run in pvc mini trunking. (not my idea.lol). So I can leave the excisting heaters and board as is. I intend to fit another small 2 way cu next to the excisting E7 cu.
What I want to know is, as both the E7 & 24hr boards are fed from the same service head and meter and they are virtually next to each other, can I use the Ze & PFC reading from the 24hr cu and just make a note on the cert? Or, would you just make a note on the cert why you couldnt carry out the live tests?
Any thoughts or info would be great. If Ive missed something obviouse, I accept your critisism.lol
Jay
Jay
