Earth arrangements confusion | on ElectriciansForums
Discuss Earth arrangements confusion in the UK Electrical Forum area at ElectriciansForums.net
Essex
Working on a old property in a slightly remote area installing a new circuit.
When I looked at the earthing it looked like a tns but I investigated and found a old 2.5mm running towards the rod.
My problem is I am getting a ze reading of 0.25 ohms.
Ino we had a really heavy down poor the day before but to be that low?
I am wait for the dno to confirm the earthing but they ain't rushing.
Any thoughts
I know a good reading for tt is 200 ohms or lower. This is the first one I have worked on
Thats is just the main cable nothing else
When I manage to peak around the wooden board covering the mains it looked like a swa with a earth strap.
It's under the stairs and I could hardly fit my head in there.
If you have an earth connection to the sheath of the supply cable and the Ze reading with all other earthing connection disconnected is 0.25Ω then the supply is TNS.
If it has a rod connected to the MET then there is an earth rod connected to the MET it would not change the earthing of the supply.
As I said I assumed it was a swa.
But looking out side there was only 2 cables going in.
So I would say that was a tube of some sort
This place has had works done but no one has left any certificates
I will have to contact dno again to comfirm the earth.
Hi Alan - I've been building up my TT portfolio lately using the larger 5/8" 4ft rods, two at a time. Around here in wet clay this has been good for 10 Ohms or less. I would need to parallel up many many of these to get your numbers, so it's def a DNO means of earthing in my humble opinion. Have you checked Ze against short circuit impedance? Avoid the non trip setting, if you get 0.25 for both then perhaps DNO has PME'd an old TT at some point.
It's a area they just keep adding to
There is power pole then when you get to a built up area they stop.
Can't find a substation near by.
I don't know if this may affect it but there is a dyke around the place and it on a flood plane
Ground soft and soak water in
Properties can be fed from pole mounted transformers not necessarily near a substation.
There is a method of earthing very occasionally used on single properties in remote locations fed from their own transformer (pnb).
Have you looked at the pole(s) supplying? If a pme overhead supply there should be a pme label on every third or fourth pole plus you will see an earthing conductor running down the pole.
Sorry OP for hijacking your thread. Wiko what surveying do you do, if any, when choosing a place to install your earth rods, so as not to hit any other services?
Just curious as I've not done one yet, and if the 18th has its way, I'd better get some practise in.
I have a three wire overhead supply from a pole transformer, bare and only the line (live lol) insulated from the last pole to the house. Three houses on this one supply.
I found those rods give a much better reading myself, going to use them from now on.
Same question for you Phil;
Reply to Earth arrangements confusion in the UK Electrical Forum area at ElectriciansForums.net
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
I think I might be tempted to test this theory, if it can be done without causing danger to anyone.
