Earth at the separation point (TN-C-S) of the DNO... | on ElectriciansForums
Discuss Earth at the separation point (TN-C-S) of the DNO... in the Electrical Course Trainees Only area at ElectriciansForums.net
C
Carlos Arruda
Hi all.
It seems there has been quite some different opinions in my classroom as to who should really change the earth cable in the incoming position where the 100A fuse is, in domestic installations.
Can any qualified electrician, change the earth cable at the DNO side? Say for example on an old installation that needs to be brought to the 21st century, will one have to call the DNO to have this upgraded?
Pic bellow.
https://www.dropbox.com/s/mc892iqcm065n6q/PME1.jpg?dl=0
Many thanks in advance.
Regards,
Albert
it's usual to have to pull the fuse to remove the cover from the Earth terminal in ones like your pic. some come with the terminal exposed, which is easy. where the fuse needs to be removed, by rights you should call DNO. ( cough, cough).
Reply to Earth at the separation point (TN-C-S) of the DNO... in the Electrical Course Trainees Only area at ElectriciansForums.net
