A
Adam Smith
A friend rang me today to ask if I could come and look at his melting CU. He said that all the circuits were holding and everything operating correctly, he only noticed something was wrong when he saw smoke coming from under the stairs!!
His land lord sent round a 'Multi trade' lad to 'fix' it, which involved just turning the shower circuit off and leaving.
I had a look today expecting to find a loose neutral melting away in there but instead found the earth bar to be the one melting!
Does anyone know what faults could cause the earth bar to overheat?
The only thing I could think of was an earth fault leading to overcurrent and a loose earth at the CU. There is no RCD and all circuits are on MCBs. IR tested the shower which was apparently the problem but all seemed fine, cables terminated correctly and all shiny and clean. Tightened all connections in CU and checked Ze which was fine also.
Cheers in advance
Cheers in advance
