R
rocker
Been thinking about using earth blocks for connection of shower cable etc.... You know, the big metal terminal block sort for connecting up 16mm earth cables, bonding and what not. They look like the inside of Henley blocks pretty much, but never have a 'rating', probably because they have no insulation, but does anyone know if they are in a suitable enclosure, could they be used to connect and extend 10mm for showers or cookers or whatever? And if not, why not? Cheers folks.
Lenny's ones, like the one at the top of the picture.
SJM thanks for the heads up, never seen them before though they just went up to 30A.
I still want to know though!
Earth block rating/using to connect phase
Australia
rocker,
rocker,
