Earth bond to external oil boiler.... | on ElectriciansForums
Discuss Earth bond to external oil boiler.... in the UK Electrical Forum area at ElectriciansForums.net
bigspark17
wales
External oil boiler, (just outside kitchen) oil pipe buried through garden to tank. Plumber says it doesnt need bonding as its outside? Am i missing something?? Copper pipes entering house from boiler.
Thoughts
Hi - guessing the boiler will be earthed via cpc, but any pipe entering the house may need bonding I'd have thought. Perhaps confirm installation instructions whether the external boiler, external oil tank and pipework needs any special treatment. Maybe Mr Plumber's done that?
I agree if the pipes entering the property from the boiler are also copper then this is bringing an extraneous conductive part into the installation and requires a main equipotential bond.
I though that pipes had to be copper within 3 meters of a boiler but could be very wrong on that?!
The PME requirements are that the tank/pipework (external) is staked down. Internally, as always a bond is fixed on the consumer side of the tap and any insulated insert. This has nothing to do with wiring regulations which are non mandatory.
Reply to Earth bond to external oil boiler.... in the UK Electrical Forum area at ElectriciansForums.net
4-5 hours for 150? no chance, this is 2024, 150 for 2 hours maybe, that said an hour seems pretty quick, not sure he did the job right
L
Underground oil tank feed problem This unit is located in France where they use diesel not kerosene. The feed from the underground tank is not...
LostinFrance
L
